Analysis with Blueprint dashboards
Greetings:
I'm attempting to implement a very simple analysis that reads a device parameter, acts on it, and writes a new parameter back to the device. This is exactly what the "Operate data from devices" example snippet appears to do.
In my case, I wish to use this analysis with a Blueprint dashboard when called from a Push Button widget.
I have changed the original:
const device = new Device({ token: env_vars.device_token });
To:
const variable = scope[0];
const device_id = variable.device;
const device = new Device({ token: context.token, id: device_id });
But the script is unable to find the device parameters. Any suggestions?
