Analysis region
Analysis region
@Anderson Viergutz
Hello!
When the Analysis starts the log shows this message:
TagoIO-SDK: No region or env defined, using fallback as usa-1.
So I guess that may be possible to define the Analysis to run in Brazil, but I can’t find any documentation about it.
When I trigger an Analysis from an Input Form, sometimes I get 5 to 10 seconds delay before I get back the first Analysis response on the Validation field in the Input Form.
I think this may be improved by running the Analysis here in Brazil. It’s possible?
Best regards,
Anderson
