* Analysis Example
* Operate data from devices
* Read information from a variable generated by devices,
* run a simple calculation in real-time, and create a new variable with the output.
* Instructions
* To run this analysis you need to add a device token to the environment variables,
* To do that, go to your device, then token and copy your token.
* Go the the analysis, then environment variables,
* type device_token on key, and paste your token on value
const { Analysis, Device, Utils } = require("@tago-io/sdk");
// The function myAnalysis will run when you execute your analysis
async function myAnalysis(context) {
const device = new Device({ token: "MYDEVICETOKEN" });
// create the filter options to get the data from TagoIO
const filter = {
variable: "no",
query: "last_item",
const resultArray = await device.getData(filter).catch(() => null);
// Check if the array is not empty
if (!resultArray || !resultArray[0]) {
return context.log("Empty Array");
// query:last_item always returns only one value
const value = resultArray[0].value;
const time = resultArray[0].time;
// print to the console at TagoIO
context.log(
`The last record of the water_level is ${value}. It was inserted at ${time}`
// Multiplies the water_level value by 2 and inserts it in another variable
const obj_to_save = {
variable: "salve",
value: "egg",
try {
await device.sendData(obj_to_save);
context.log("Successfully Inserted");
} catch (error) {
context.log("Error when inserting:", error);
module.exports = new Analysis(myAnalysis);
// To run analysis on your machine (external)
// module.exports = new Analysis(myAnalysis, { token: "YOUR-TOKEN" });
