Having a Analysis that reads the last 2 variable values (v_pulse, v_lastAccumulated) and creates a new one (v_accumulated) that is the sum of first both, how do I set the v_lp timestamp into the new one (v_accumulated)?
v_pulse, v_accumulated should appear in the same row when they appear into a dinamic table based on the timestamp, but not!
const device = new Device({ token: device_token});
const c_lastPulse = {
variable: “pulse1”,
query: “last_value”
const [v_pulse] = await device.getData(c_lastPulse);
context.log('Last Value - '+require("util").inspect(v_pulse));
context.log('Value to add: ' +v_pulse.value);
const v_time = new Date(v_pulse.time).toISOString().replace(/T/, ' ').replace(/\..+/, '');
context.log('Time to set--'+v_time);
const c_lastAccumulated = {
variable: "accumulated",
query: "last_value"
const [v_acc] = await device.getData(c_lastAccumulated);
context.log('Last Accumulated - '+require("util").inspect(v_acc));
var v_accumulated = {
value: v_acc.value + v_pulse.value,
time: v_time
await device
.sendData(v_accumulated)
.then(context.log(“Accumulative counter”));
It doesn’t work. I tried timestamps as well…
