case 0x03:
pack_type = "temperaturereport";
sequence = input.bytes[2];
device_time = (input.bytes[6] | input.bytes[5] <<8 | input.bytes[4] <<16 | input.bytes[3] <<24);
var sensor_1_min = (input.bytes[7] << 24) >> 24;
var sensor_1_max = (input.bytes[8] << 24) >> 24;
var sensor_1_flow_count = input.bytes[9];
var sensor_1_compliant = input.bytes[10];
var sensor_2_min = (input.bytes[11] << 24) >> 24;
var sensor_2_max = (input.bytes[12] << 24) >> 24;
var sensor_2_flow_count = input.bytes[13];
var sensor_2_compliant = input.bytes[14];
var sensor_3_min = (input.bytes[15] << 24) >> 24;
var sensor_3_max = (input.bytes[16] << 24) >> 24;
var sensor_3_flow_count = input.bytes[17];
var sensor_3_compliant = input.bytes[18];
return {
data:
"type" : pack_type,
"sequence" : sequence,
"devicetime" : device_time,
"sensor1mintemp" : sensor_1_min,
"sensor1maxtemp" : sensor_1_max,
"sensor1flowcount" : sensor_1_flow_count,
"sensor1compliant" : sensor_1_compliant,
"sensor2mintemp" : sensor_2_min,
"sensor2maxtemp" : sensor_2_max,
"sensor2flowcount" : sensor_2_flow_count,
"sensor2compliant" : sensor_2_compliant,
"sensor3mintemp" : sensor_3_min,
"sensor3maxtemp" : sensor_3_max,
"sensor3flowcount" : sensor_3_flow_count,
"sensor3compliant" : sensor_3_compliant
}break;
