Add Label to Line Chart Reference Line
When you go to add a reference line via variable there is no option to rename your variable with an alias name. This is something you guys should add and the alias name be display above the reference line.
Some other features that would be benficial:
1. Choose if reference line label is on the right or left side of graph.
2. Add reference line to the tooltip just like any other variable when hovered.
