Static IP and Firewall Rules
This topic explains how companies that operate in work environments that require a static IP (fixed IP) can connect to TagoIO without using the DNS.
TagoIO's back-end servers have static IPs that can be added to your firewall in order to allow end-point devices and web clients to access TagoIO.
Nevertheless, we do not recommend to program your end-point devices (sensors) to communicate with TagoIO by using a static IP. The reason for this is that when using a static IP you may lose the security offered through our certification system. At some point in the life-cycle of the project, the certificate can be renewed on TagoIO's side without advanced notice, and this can prevent the devices from accessing our servers.
Here is a list of static IPs that you could use:
ServicePrimary IPSecondary IPTCP Ports
API75.2.65.15399.83.158.6480443
Realtime75.2.27.15899.83.235.8480443
MQTT75.2.83.13099.83.172.11918838883
Note that the TagoIO Admin (admin.tago.io) does NOT offer a static IP because it uses a content delivery network (CDN). This means that every time users request resources from the Admin, the system will use the servers closest to them.
    • Static Table Widget
      Static tables are tables where each cell represents a different piece of information, and it can either be fixed text or data from a variable. Editing the static table It is possible to customize widget color, apply a formula to a cell, edit options, ...
    • Sending Data
      A device can send data to TagoIO by using the POST method. POST https://api.tago.io/data KEY TYPE REQUIRED variable string [max 100 characters] yes unit string [max 25 characters] no value string/number/boolean [max 6kB]  no time string no group ...
    • API Overview
      It is easy to connect devices, data sources, or third-party APPs to your account using TagoIO Application Programming Interface (API). We have a comprehensive set of APIs that gives you full control to manage your accounts, data, devices, dashboards, ...
    • Tables
      Table widgets present your data in a tabular way. You can also allow users to change values on the cells, delete rows, and more. There are two types available: the Static Table and the Dynamic Table. Static Table It is one of the special kinds of ...
    • Middleware
      Through a TagoIO middleware, companies can connect devices using their own protocol. The middleware acts as a protocol converter from any type (TCP/IP, UDP, ...) to the standard TagoIO APIs. For more information on how middleware is done, check our ...
      Aug 30 - Join us at TagoIO Connect Global, our annual conference. Learn new features and use cases. Register Here
        Future and past Webinars
