Hi, I’m trying to connect a Khomp NIR21LI endpoint (Zigbee) to Tago using Khomp ITG200 Gateway (Zigbee). I read the post about ITG200 but it’s related essentially to LoRa, despite it has a note about Zigbee integration. But the original Zigbee connector is no longer available and I couldn’t make it work.
I used the HTTP configuration (same as link above: URL base and SSL, port, username, pass, standard certificate).
Any tips?
