TagoCore v1.0: Simplified Plugins, Docker Support, Direct Repository Access and much more
Hi everyone,
We are happy to announce the release of TagoCore v1.0, our open-source IoT platform for edge computing. If you've been with us during the beta phase, you're already familiar with our focus on adaptability and efficiency.
What's New in TagoCore 1.0?
  1. Monorepo Setup: All plugins are now integrated into the main codebase, streamlining development and management.
  2. Open-Source Public Plugins: Public plugins are now fully open-source, allowing you to explore and customize them to fit your needs.
  3. Simplified Private Plugin Deployment: Deploy private plugins by dropping the plugin folder into the TagoCore Console. No building or bundling is required.
  4. Docker Images: For consistent and easy deployment.
  5. Direct Repository Access: Experience a more hands-on approach by accessing the repository directly.
  6. Backup and Restore: It's possible to add backups for your device data to TagoIO and from TagoIO to TagoCore.
These enhancements are designed to transform your interaction with TagoCore, making it more seamless and efficient.
Why the Change?
We've listened to your feedback and have worked to create a version of TagoCore that aligns with our community-driven vision. The old Plugin Store is being phased out, and with TagoCore v1.0, all plugins are integrated into the main codebase. This change simplifies the process and supports our open-source goals.
Private plugins have also been upgraded, allowing you to deploy without compiling hassles. Both TypeScript and JavaScript plugins will work seamlessly.
The Plugin Store API is also being phased out, allowing TagoCore to be more flexible and offline-ready.
Join the TagoCore 1.0 Experience
Your feedback is crucial to our development process. As we finalize this release, we invite you to share your thoughts on TagoCore v1.0 on the TagoCore community page.
