Formula and Tags
Formula and Tags
Hello,
What is the easiest way to use a tag value in a widget's formula feature? Is it possible or i should create a analysis just for that? If yes, do you have any demo?
Ideally I want to calculate a new data based on my device raw data and a constant value (which would be a tag for that particular device).
For instance:
device variable : x;
device tag:
Name: y, Value: 3568
BluePrint Device MyDevice
Variable: x
Formula on a specific widget: ($VALUE$ * y)
Thanks !
